hardtobe
Feb 13, 2014Explorer
g sturgill wrote:
Hi all, I have a 2000 rexhall airbus with a 110 circuit not working. There are no tripped breakers or gfi issues. I'm plugged into a 50amp box, and the house batteries are in use. The inverter is in the charge mode. The circuit in question runs the tv and 3 other outlets. Everything else is working fine. Any suggestions woul be appreciated thnks, g
one thing u never mentioned.U said its not the GFI? IF there was no power at the GFI you would not be able to test it.IF you have power at the GFI and were able to test it then its not a tripped breaker at the inverter or the GFI u tested is not in the circuit that's out.
38,766 PostsLatest Activity: Jan 10, 2026
