pashir's avatar
pashir
ride hight valves
might have a leaking valve. found adjustment for rear suspension at 7" or 7.5" depending on specs?? Gillig chassis. no info for front suspension in my manuals. '97 country coach. need more info.
thanks in advance
Paul
  • I would spray the valve and fitting with soapy water and look for bubbles. It would probably be best if the the engine was running and the system in "Travel" mode. This would apply air to the ride height valves, air line and air bag.
    In "Leveling" mode does that air bay loose air if you turn off the auto leveling?
  • Contact Gillig with your VIN on Monday for the ride height specs.
