creeper wrote:
msmith1199 wrote:
For those that keep giving advice about pointing the motorhome into or away from the wind, it won't work! The wind direction is going to shift as the storm passes. And if it passes directly over you the direction is going to change 180 degrees from one side of the eye to the other.
Yes then you turn around, this is only if you get STUCK in a storm, not something is recommended. Same thing goes if you're hiding behind a building. When the winds start to shift you move.
So go back to the RV in the middle of the hurricane and turn it around as the wind shifts? Huh?
