Hi, We are looking at buying either a used Roadtrek or a PW. It seems a challenge to find a decent one for the right price! I was wondering, though, after looking at the configuration of these, if gro...
A trick that I have used in the construction business is to drive forward until the rock is at the top and then place a long 2x4, steel bar or cut sapling under the rock, between the tires and above the axel and back up. This will usually dislodge the rock. You can also put the L wheels at the 2 O'clock (R. wheels at the 10 O'clock) position and place a short 2x4 vertical and back up a bit.
