Landis's avatar
Landis
Upper clearance lights
I really need some help. I have a 2011 Tiffin Open Road 32'CA. I was replacing a roof clearance when the wires are to short to replace the light. I tried to pull more wire but it broke. Does anyone know where the wires run. I cannot get to them through the cabinets. There is a space between the windshield and the cabinets. I really need some help.
We are leaving soon to go back to Florida.
  • I replaced the clearance lights on my Damon Escaper with LED lights. The lights were all chained together like K Charles said. I pulled new wires do to the same problem that you mentioned. When I replaced mine, I soldered the wires and used heat shrink tubing so that it was a do it once job.
  • Wait till you get home, nobody is going to stop you if you have a light out.
  • ^ This. If you tap into one of the other clearance lights, can you fish the wire over to the one that's Mia?
  • Take off another light they should all run off the same wire.
  • To get to the wires you will have to remove the cabinets and take down the paneling.
