B_B_Upch's avatar
B_B_Upch
roof clearance lights
I'm trying to change out my clearance light on the roof of my 96 allegro bay. It is leaking & when I checked it the base is busted so no quick fix. It needs to be replaced. The only problem is that it seems to screw in from the bottom? There is a thick washer & then a small washer that seems to hold the screw in? Ant clue on how to get these lights off? Or do I have to take apart my ceiling inside the rv to get them off? Thanks
