B.B.Upch wrote:
OK so I figured out how to get the old ones off & I got the new ones in the mail.
New problem
The old ones have 2 wires (black & white) &
The new onea have 1 black wire.
An suggestions on how to wire them in? Thanks
That is why I mentioned to get the TWO wire replacement lights back on page one of this topic. Since these will be mounted on the fiberglass portion of your coach, you do not have the ground available like you have with a steel vehicle surface. You will now have to fabricate some type of a wire connection between the ground wire on your coach to a location on your light fixture that will act as the ground. The black hot wire will hook up to the 12 volt connection.
