Fishhunter's avatar
Fishhunter
Clearance lights
What to use to seal clearance lights on front of TC. Seems this is a common spot for leaks.
  • I used ProFlex on mine when I replaced them with LED clearance lights.
  • IMO you should take off the lens loosen the screws, lift up the light and apply Dicor or equivalent around the wires and screws. Then screw it down. If the lens is loose I applied a very thin coat of (God forbid) silicone, but just where the lens touches the base.
    Good luck!
