john_d_dobbs's avatar
john_d_dobbs
Clearance/Tail Lights Not Working
We have a 2008 Winnebago View 24H and we're on the road this week. The 5 red lights along the top rear of the RV - clearance/tail or lamps (or running lights) are not lighting. I believe they are supposed to be lit when the engine is running or at least while the transmission is in gear. Brake lights and turn signals are working fine.
I first started searching for fuses under the drivers seat and then under the drivers side foot area. There are lots of fuses there with no clue as to what they are for - I don't seem to have a fuse panel diagram.
I did find the automotive and coach circuit breakers under passenger seat and there is a breaker there marked CLEARANCE/TAIL LAMPS but that appears to be Ok.
Any other hints as to where I might look for the cause of this problem?
Thanks,
John
