Bordercollie
Dec 22, 2016Explorer
Find out where the clearance lights, etc. are grounded and if there are relays that may be defective from Winnebago. Make sure ground connection(s) for lights are clean of corrosion and tight. Fuse holders have connections with screws that can become corroded or loose. The grounded outer shell of bulb holders can become corroded and not make good connection to bulb bodies. A good Winnebago dealer service department should know how to find the problem(s)and advise you.
38,782 PostsLatest Activity: Sep 21, 2026
