klutchdust
Sep 16, 2015Explorer II
gbopp wrote:
I don't think the ceiling fan is Road Warrior specific.
Did you check fuses? Is the switch bad?
Use a volt meter to make sure you have power to the fan.
It may be something simple.
Most RV 'stuff' is made by different manufacturers and is readily available. Will the blades turn? Sometimes the shaft on the motor needs a drop of 3 in one oil. Needs to be upside down though. Let it seep
into the motor.
38,771 PostsLatest Activity: Apr 15, 2026
