want-a-be
Sep 07, 2014Explorer
Gjac wrote:
I have the Demco tow bar steel with a 10,000 lbs capacity. It is 10 years old with 75,000 miles on it. It has a life time warranty. Having said that my tow car only weights 2,600 lbs and I have taken it apart to clean and inspect it for wear. If you are way under the towing capacity, most of you towing has been on hiways and is set up at the right towing height I would take it apart and clean and inspect the parts, reassemble and feel good about it. What is the capacity of your tow bar vs your tow car wt?
Tow bar 6000 lbs. tow car 3000 lbs. always made sure it was level and all towing on highways. Thanks
38,777 PostsLatest Activity: May 20, 2026
