Sam Spade wrote:
rgatijnet1 wrote:
They will mount an unmounted tire for free or install your spare tire for free. They will also bring out a replacement tire, either new or used, depending on what is available.
Apparently Coach Net is the only one that claims to provide that kind of service....because GS and AAA certainly DO NOT. Their only options are install a mounted spare or tow.
And then it depends on where your failure occurs. It takes a pretty well equipped service truck to be able to mount a truck tire at the side of the road.......and those just aren't always available within a reasonable distance, no matter who your service provider is.
Have you ever watched a guy mount a truck tire on to a rim? Usually it takes about 15 minutes using tire irons. That is all it took the one time I needed a tire changed. That is why many RV owners carry an unmounted spare. The only thing a service truck is needed is to carry the air compressor to add air after the tire has been changed.
