RnRs-RT
Oct 08, 2016Explorer
If it is the same as mine it is a plastic hinge so you can use the old holes or make new ones thru the plastic hinge. There should be a profile of the hinge on the link I posted 10/6 9:52 pm. It will show that there is plenty of room for the bolt heads. I just used approximately the same amt of bolts as they used pop rivets. It has been a while but I think I used the old pop rivet holes to install the hinge to the door but I just drilled new holes when I installed to the van as I was unable to see the old holes after I raised the door into place. The plastic hinge has no holes at all. Just drill where they are needed.
