nbking
Jul 21, 2015Explorer
Roadtrek Water Pump
My water pump barely makes a sound when I turn it on. It appears to be working at minimum power. When I leave it on for a few minutes and then turn the water tap on, water comes out in spurts and then stops.
Is my water pump finished or is there something I can do to fix it.
I did check to make sure there was water in the tank. Since it is working somewhat, I assume the fuze is OK.
The placement of the water pump makes it difficult to see whether there are any loose wires. I could have a look at that if it seems to be a matter of a loose wire somewhere.
Any assistance would be appreciated.
