Hey, this is davidharvey my question was how to remove the back connection of the water pump. My plan B was to remove the motor from the pump which should allow the pump to rotate in order to remove the threaded coupling to the water distribution tee. It worked fine, but who designed these sytstems? By removing accessible water fittings and mechanical connection to the bulkhead, I removed the screws holding the pump to the motor. Two were relatively easy and the third was done with mirrors, flashlight, a stubby phillips, a pair of pliers and lots of creative discription. The motor was removed, the pump was unscrewed and now i will replace it with modifications to make it servicable in the future. I found gasket debris in the pump.
Does anyone else fix their campers? Seems like this kind of question must be asked once in a while. Where's the love?
