I hope you get that squirrel out of there quick. One got into my Genset Bin and chewed my wiring harness cost me over $1,000.00 to rewire and the Genset had to be lowered to the ground out of the bin to rewire on the backside of the Genset. I don't believe in using food to lure rodents into my coach. Did that one time never again! I use a electronic device, 2 of them one inside my coach behind the engine compartment and the other inside my coach in the rear of the coach. Then, I went to Lowe's and bought Double 00 Steel Wool lots of it and filled every nook and cranny in my RV and every entry way that I could find under my coach! I also use the steel wool in and around my Genset. After doing this I haven't had a rodent in my coach in about 6 years. Good Luck in whatever way you decide to go!
