I have an appointment to get a 15,000 roof ac checked tomorrow. I think it is losing freon which will require a new one. I am considering a possible Heat Pump or at least new ac with heat strips. M...
I use my roof top heat pump every Winter but it only works down to about 32 degrees. Other than that limitation, it works great to cool and to heat our coach. I have a portable heat pump that I also use inside the RV that we have used in sub-zero temps. It uses less amps than a resistance type heater.
