I have an appointment to get a 15,000 roof ac checked tomorrow. I think it is losing freon which will require a new one. I am considering a possible Heat Pump or at least new ac with heat strips. M...
How often are you going to be in sub freezing weather? I think having the heat pump is a good thing as an option instead of a separate electric heater. Ours works fine and if it's too cold for it to be effective then I probably want the furnace on anyhow to heat the tanks and water lines.
