choppermtn
Aug 13, 2019Explorer
roof air
I need to replace my roof air . I have replaced one before but this one is ducted and has no access from the inside of coach How do I remove the roof unit to replace it?
dougrainer wrote:Two Jayhawks wrote:choppermtn wrote:
Thanks everyone for the info
Also, my lag bolt heads are covered in silicone requiring removing silicone to remove lag bolts. Since it came that way from Newmar I reinstalled new silicone after tightening bolts.
Yes, you can do that. What I do is, after installing the lag bolts, I remove and inject silicone into the hole then reinstall the Lag bolts. There is no need to install Silicone over the top of the bolt when you do this. Doug
