choppermtn's avatar
choppermtn
roof air
I need to replace my roof air . I have replaced one before but this one is ducted and has no access from the inside of coach How do I remove the roof unit to replace it?
  • Chris Bryant wrote:
    Yours is going to take a very specific replacement, depending on what you have. It is lag screwed in, instead of bolts. Here is a picture from one of the training power points showing a Newmar install.
    NOTICE that gasket that goes between the 2 roof holes. THAT gasket is critical for correct operation. It separates the Intake hot air from the cold exhaust air and if not installed or installed incorrectly, you will not get adequate cold air output. The Lag bolts are installed into a wood/aluminum backer plate. Just make sure you measure and drill the 4 holes in the New AC mount pan, exactly where the original ones were, Do NOT over tighten the lag bolts or you can strip them out of the Aluminum plate. Doug
  • Yours is going to take a very specific replacement, depending on what you have. It is lag screwed in, instead of bolts. Here is a picture from one of the training power points showing a Newmar install.
  • I have a 38ft. Newmar Mountain Air , ford chassis , v10.Dometic a/c now .
    I think I saw the 4 bolts that you are referring to I just don't know if when they are removed anything will "fall" between the roof and ceiling making It near impossible to install the new unit . Are there any "tricks" anyone could share ?
  • choppermtn , you should give some info so someone can know what you
    are working on . Tell us what brand of coach , year , make of a/c etc
    You may even find a picture on line we could look at
    What you described does not sound like most coaches or at least like
    anything I have seen .
  • A1RVTraveler wrote:
    There will be four lag bolts that mount through the AC unit into the roof. You will need to remove the AC cover to see them.
    X2
  • There will be four lag bolts that mount through the AC unit into the roof. You will need to remove the AC cover to see them.
  • The ceiling is smooth with small round intake and blower holes throughout the rv .Nothing below the unit.The intake holes have small filters in them.
  • where is the air intake and the air filter? that's where the access should be what is right under the ac unit on the ceiling?
  • I dont know the answer, but my guess would be that it's somehow clamped to the roof from the topside. I'm curious myself.
