Geocritter's avatar
Geocritter
Roof-top AC acting oddly
I have a question about the original roof-top Dometic AC unit on my 1994 Holiday Rambler MH. It seems to be generally working okay, keeping the MH cool during the day (not an easy feat in Austin TX now that summertime is upon us). What has me concerned is that in the mornings, when it’s still fairly cool out, it sounds as if the AC compressor is turning on without the fan kicking in to move air through the unit. It sounds at first like a hum, then the hum gets louder as if the compressor is laboring harder, finally the unit will turn off with a sound like a very mild ka-thunk. It’ll remain quiet for 15-20 minutes and then start the cycle over again. Through all this the fan that blows air through the unit never goes on. Later in the morning, as the day heats up, the fan does go on and the AC general behaves normally. Does anyone out there have an idea what’s going on? Should I be concerned?
Thanks in advance for any help and insight y’all can give me.
Steve
  • Blower motor might need some lube. With the breaker off, go on roof and remove cover. Spin fan motor and drip some light oil on the shaft. That might do it.
