dougrainer
Mar 15, 2020Nomad
Do you have the FAN set to AUTO? Doug
Fan Speed Press the FAN button to select the desired fan speed. Each successive press will advance to the next available speed. Your selections will be Auto, LOW, MED, and HIGH. The fan will run continuously during LOW, MED, and HIGH fan settings. The fan will cycle on and off with the thermostat on AUTO setting. See “Special Features” on page 8 for more information on auto fan.
To set Aqua Hot instead of furnace.
“FURN” / “AQUA” - Furnace or Aqua Mode (Factory setting is “FURN”) To change the setting from “FURN” to “AQUA” or visa versa, simultaneously press the up and down buttons. The LED will display the selected option.
