Tonijim wrote:
Our 2010 Class C rooftop ac unit is operating just marginally. I've been told that they are "sealed units" and to recharge their freon coolant is tough. Who has had this work done and what has been the experience?
Thanks, Jim
An air conditioning unit doesn't consume freon in a sense like an engine consumes oil. If the freon is low it has a leak. Like a refrigerator at home, access ports may have to be installed/soldered into the lines to install gauges to determine the problem. If you can access the roof and remove the cover look for any spots/connections that may have an oily residue. Oil leakage occurs with freon leakage. Start calling around and see what mechanics charge to diagnose and repair. Also look for any defects in the coils where a limb or something bent the fins. Many times coils leak from the tubes . As JD said, inspect other items first.
