If you are talking 1998, then Freon 22 is the Freon to use. BUT, most units use only 16 to 20 ozs of Freon. HOW did you determine the correct Freon fill capacity? There are only 2 ways to fill a Roof RV AC
1. Dial a Charge
2. Temp corrected amp draw AT the compressor
Regardless, your Compressor is not caused by your fill. You have a bad compressor. YES(or NO) you will not find a replacement Compressor for a RV Roof AC unit. They have not made replacement compressors for more than 30 years as it was cheaper to replace the upper unit complete than pay to replace the compressor. Doug
PS, since you are handy brazing the lines, LEAVING the Line taps on is foolish. You only install Line Taps to safely(EPA) drain any possible Freon still in the system and then braze the Line Tap pin holes and braze in standard copper Schrader valves. Line Taps WILL LEAK. Eventually.
