rgatijnet1
Aug 20, 2019Explorer III
I assume that where you are parked the voltage is stable and not going up and down. Circuit breakers will wear out so you might try replacing the breaker that is tripping. Also at some electronic stores you can buy an aerosol can of spray coolant. With this you can spray individual components to see if cooling any of them solves your problem.
