DFord
Aug 20, 2019Explorer
You cleaned the coils but did you really get them clean? How's the air flow through the coil on the roof? If it's still blocked, the symptoms you describe make sense. The problem sounds related to heat build up on the condenser (outdoor) coil side. The heat isn't being rejected fast enough. Air flow through the outdoor coil is critical.
38,783 PostsLatest Activity: Sep 23, 2026
