oldave
Aug 20, 2019Explorer
I fear ultimately Doug is going to be correct , bad compressor .
Before condemning it though I would give the condenser coils
on the roof a through cleaning again . Stuff can get imbedded and some
areas are hard to get at .
Also some A/Cs have a foam rubber strip under the plastic cover
that helps keep the air flowing through the coils , it needs to be
in place or some air can bypass the coils .
Do you know what the park voltage is ? Low voltage can cause problems .
This time of the year everyone is running their A/Cs full blast which
causes low voltage through out the park or probably the entire area .
Ray
Ray
38,783 PostsLatest Activity: Sep 23, 2026
