lyonsfin's avatar
lyonsfin
Rooftop AC Weird???
I have a 2009 Simba with 2 Carrier roof units. The rear AC works when plugged into 20-30AMPS (at my house)and when the generator (50AMPS) is running. The front unit will only run when plugged into house and NOT with generator running. I do not have the ability to plug my shore cord into a dedicated 50 AMP line here.
  • Again, one unit operates on generator or plug in and one unit only on plug in All circuit breakers appear ok.
  • It is pre wired. I do not know of an activation switch. There was an outlet or two not working, it is NOT charging the house batteries.
  • Are there other things or outlets not working whenon generator?
    Do you have a transfer switch that activates when you’re on generator?
    Is your generator pre-wired or do you have to plug the shore cable in to the generator?
  • I believe that when you have the generator running, the house plug does not supply any power to your coach. It is an either/or with the generator taking preference.
