Dennis12
Jan 21, 2017Explorer
The gas that we are buying is not as good as in the past with the ethanol in it. When you know it is going to be setting for an extended period of time you should double the mix that is specified on the directions on a bottle of Sta-Bil. (Walmart). You should do this to all gasoline engines. After putting it in the tank then add gasoline to mix and leave the unit run for 15 minutes or so to be sure that the Sta-Bil has made it into the engine.
