pauldub
Jan 21, 2017Explorer
"the engine CLICKS over but just no start up" Not sure exactly what you mean. Do you just hear clicks or does the engine crank every time? I'd first check for stored engine codes because that's the easiest first step. The ECU can store codes before it decides that it's time to turn on the check engine light and those codes can give you a good hint at what the problem may be. You can also check the fuel pressure when it doesn't want to start. I'm assuming there is a port on one of the fuel rails where a pressure gauge can be connected.
