Teddy5213 wrote:
Really enjoy the amenities on our 2015 Holiday Rambler 36SB Vacationer but tired of the stiff suspension and loose fasteners from the ride.
I installed a Safety Steer stabilizer and it did a great job of preventing sway from passing semis and road swailes but the ride is rough and has managed to loosen the dash panel and break the windshield seal.
I've investigated several options and short of trading the Stealth in for a diesel pusher with air ride suspension I have yet to find evidence that any of the current products on the market will soften the ride.
Most of the comments reviewed deal with the air bag or foam bag systems that boast improved handling and reduced sway but do not address the handling of the shock effect of rough road, railroad tracks, and bridges found on most east coast interstates.
Has anyone find a cure to help the rough ride on the F53?
there is no way you can soften the ride.you can make them handle better for sure.The suspention is stiff and designed to handle the loads
lower air pressures is about it. certain shock designs are designed to rebound at softer rates.
US roads are bad bad bad and even my air ride independent suspention 40Ft pushers rides rough on some of these terrible road conditions
