Dec 17, 2014Explorer
If you install a hitch mount just for the spare tire kit just like the RT has you should be able to mount it on a PW. It is awkward and heavy and blocks the cargo door. The newer spare tire kits have an assist to help lower and raise them though when I tried the new one it was more awkward. The only way that I made mine manageable was to have an EZ-Lift installed - designed and manufactured by a gentleman in CT. I don't know if this will install on a PW as it must be bolted through a hole at a specific spot on the chassis frame.
As to the spare tire being used as a table - well it folds down somewhat flat but it is low to the ground just below bumper height. It can be used as a table if you cover the tire with a board and sit at very short stools.
38,769 PostsLatest Activity: Mar 31, 2026
