tropical36
Mar 26, 2018Explorer II
wolfe10 wrote:
I am always a bit reluctant to offer advice on mountain driving.
There are TWO aspects that must be considered:
The rig.
The driver. While advice from a guy living and driving most of his life in the Rockies with exactly the same rig could, with all confidence say NO PROBLEM, that exact same route might be extremely challenging to a "flat lander".
Knowing how and when to use engine braking, how and when to use service brakes, the need for brake fluid to be good (not hydrated), etc do not necessarily come with a driver's license.
All true, but unless a member specifically asks how to descend a steep grade, then we must assume that they're proficient in the operation of their rig over all kinds of terrain.
I would hope that most of us know that using your brakes when descending, should be done sparingly and if not, then you're not geared down to where you should be. Even then, there's a proper way to apply your brakes when necessary.
