pnichols
Nov 08, 2014Explorer II
All fiberglass RV roofs may not be the same.
You want one that's all one piece - instead of being flat fiberglass sheets with seams on the roof between the flat sheet edges.
You want a fiberglass roof that has a crown in it - not flat.
Also, you want one that has it's edges - at least all along the long side runs of the coach - rolled over 3 or 4 inches so no 90-degree seam is present right at the roof edge where rooftop fiberglass meets sidewall material.
38,782 PostsLatest Activity: Sep 10, 2026
