wa8yxm wrote:
If your motor home is a 50 amp odds are you have spare slots in your breaker panel
Just put in a 20 amp breaker and 12-ga wire (12/2+ground) to a outdoor type outlt on the back of the house (RV). You might wish to go Twist Lock on that outlet and plug.. (If you intend to leave hooked up going down the highway) or not. That way you have power there no matter if on Shore or Generator.
It's a 30 amp rv. Twist lock is a good idea. I plan on leaving it plugged in going down the road. I don't think I have a extra slot for a breaker.
