DownTheAvenue
Sep 14, 2017Explorer
azdryheat wrote:
Your house 50 amp is different than an RV 50 amp. Your house runs two hot leads and a ground while the RV runs two hots, a neutral, and a ground. What an RV circuit actually is is two 120 volt separate circuits. Nothing in your RV requires the 240 volts your house delivers. You RV only needs 120 volts. Your RV fuse box will be divided into two separate 110 circuits.
This is not totally correct. Without getting into a details that will make anyone's eyes bleed, armchair electricians should be very careful dispensing advice.
