sayoung's avatar
sayoung
50Amp diagram
I tried a search allready and came up "no joy".I saw someone a while back posted a wiring diagram for the 50 amp power plug .I am adding a plug out to my 5er shed and want a diagram.I am pretty sure how to wire it but I want to KNOW for sure.
I realize ita actually 2 110V 25amp max circuits and not 220v 50amp,or am I thinking when I should be sleeping.
  • RoyB's avatar
    RoyB
    Explorer III
    This is how a typical RV camp ground pedestal is wired to provide 50AMP and 30AMP service...
    This is a simplified RV 50AMP Distribution pictorial
    This is a simplified RV 30AMP Distribution pictorial
    Drawings from google search
    Roy ken
  • sayoung wrote:
    ...I realize ita actually 2 110V 25amp max circuits and not 220v 50amp,or am I thinking when I should be sleeping.
    Wrong. It is two 50a 110v circuits in tandem which is also 50a at 220v.
  • A fifty amp RV plug is the same as a four wire range cord body.
  • thanks,its just a standard 50amp 4 pole plug I see.
  • Maybe you should try sleeping? :B
    50 amp 240 volt. Around here it is 110 and 220 volt so two 50amp lines of 110 = 220
    Also you can check Here
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
