WASTATELIVING's avatar
Nov 01, 2021
Electrical issue on 50amp service
I've got a new fifth wheel on 50 amp service. Recently we have lost power to all of our outlets and both electric fire places. After checking each plug, checking to ensure no breakers are popped, all fuses are intact, and the source is good this is what I've discovered.
The power supply cord is supplying 120v on both legs. When plugged into the RV our LED light above plugs shows power. At the breaker panel however, the red leg shows 120v and the black leg shows 70v. which matches the voltage I'm getting at the outlets. This is BEFORE it even reaches the breaker. I am assuming that the issue is in the inlet plug on the wall of the RV. Either a loose wire or it just needs to be replaced. I'll be opening it up tomorrow to take a look and replace it.
Any other ideas, something I might be missing?
Thanks
-Dre
