wa8yxm
Nov 02, 2021Explorer III
larry cad wrote:vermilye wrote:
Check all the neutral connections. A loose or open neutral can cause different voltages between legs.
This is your problem. 70 volts almost always means an open neutral connection.
I would agree with you Larry if the other leg was not still showing 120 with an open neutral if one leg is 70 the other should be 170 so the total is 240..
This is why I think it's the low voltage leg that has a screw loose.
