Busskipper
Sep 14, 2017Explorer
Tom N wrote:
50 AMP RV WIRING
50 AMP HOT TUB/RANGE/WELDER WIRING
NOTE: THEY ARE IDENTICAL
Tom, W3TLN
Yes will be interesting to see if he has the same - as his picture is only of the FUSE BOX.
14-50R NEMA receptacle is 4 wire, rated at 50-Amp 125/250-Volt
This is what is needed and if wired correctly should be fine - The Ground Fault thing is not something that I would think should be there in the Fuse Box.
But will leave that to the "Real" electrician, which you should consult with.
