ScottG
Sep 14, 2017Nomad
rhagfo wrote:mike brez wrote:enblethen wrote:
GFI breaker.
Disconnect the neutral from breaker and connect it to the neutral buss. Disconnect smaller neutral from breaker that goes to neutral buss.
I'm pretty sure doing this will solve the problem. I'm going to grab a different breaker without the gfi so I have it when electrican comes.
Would likely solve the problem, it now is not code compliant as the you have defeated the function of the GFI!
FOr a 50A outside outlet, it is code compliant to not have a GFCI.
