CA_Traveler
Sep 14, 2017Explorer III
OP, It's also entirely possible that the rig has a ground fault. Have you plugged into a 20A GFCI plug and turned various equipment on/off to check for a ground fault ie tripped GFCI? You have a 20A GFCI CB in your panel - what is it connected to?
We should all do that check periodically.
