CA_Traveler
Sep 15, 2017Explorer III
mike brez wrote:A 120/240V 50A RV plug is not the same as the older 240V 3 wire dryer plug. The 50A RV circuit is the same as newer 120/240V 4 wire dryer but the dryer circuit may be less than 50A.
With that being said just out of courisity if the dryer and rv have the same readings at the female end I take it that the single 240v for the dryer and the split 120v lines for the rv it is all in the wiring on the inside the dryer or in the rv panel?
The 20A and 50A RV plugs are in fact common household plugs. The 30A plug is unique to RVs.
You definitely want the 120/240V 50A RV plug. You can also have a 50A GFCI on that circuit. If the GFCI trips then you'll need to resolve the rigs ground fault. 50A GFCIs are more common for pools, spas, etc.
