mike_brez
Sep 16, 2017Explorer
mike brez wrote:time2roll wrote:
OK looks like the two feed the inverter. One for pass through and the other to power the battery charging.
Need to pull those two wires off to isolate the main panel. Also need to shut the two 20 amp inverter breakers off.
Then one last try at the 50 amp GFCI.
Thanks I'll give it a try in the am.
Ok shut off the two 20amp breakers and removed those two black wires on top.
Ems reads ok,turned on main 50amp breaker in Moho and flipped all breakers on one at a time and all good. Then turned on the two 20amp ones and still all good.
Went to re connect the two black and triped the 50amp gfi in my basement.
