pianotuna
May 26, 2014Nomad III
Hi,
Depending on the air conditioner it might or might not start.
If your motor home has two extra large high output alternators (one dedicated to the "house") you might be able to run the air conditioner while driving at highway speeds. It most likely will burn out a standard alternator.
If you have a rather large solar system (1250 watts and up) you might be able to run the air conditioner when there are perfect solar conditions.
If you have a LI battery bank with 20 kwh hours of storage you may be able to run off the inverter--but there will need to be a way to replenish the battery bank.
It is likely cheaper to run the generator for running the roof air while driving down the road.
Step one would be to try it and see. If the inverter shuts down then you have your answer.
38,766 PostsLatest Activity: Jan 10, 2026
