Robert_Kesselri's avatar
Aug 20, 2018
Having problems running AC from inverter.
I'm converting a cargo trailer into a camper. Over the weekend, I tried to install an AC unit. The unit that I bought requires 8.8 amperes at 115 volts. My inverter is an 1800 watt trip lite that I have had installed in my truck for several years. I've used the inverter to run power tools, electric kettles, and other high current loads, so I'm pretty sure it works fine, and should support 15 amperes without difficulty. When I try to run my AC unit though, it runs the fan for 3 minutes, the compressor never comes on, and then the inverter shuts down. I monitored my 12 volt supply while doing this, and it never even flickered, 13.5 to 14 volts the whole time (engine running) I took the AC unit into the house to see if it would run from a mains outlet, and it does.
So...
If there's nothing wrong with the AC unit, nothing wrong with the inverter, and nothing wrong with the low voltage supply to the inverter, what could be the problem?
