derh2o wrote:
Looking at my Onan generator manual, it says i should run it for a minimum of 1/2 hour each time I started it. My wife would like to run it from 5-10 minutes to blow dry her hair.  Or, put something in the micro for a couple minutes. Assuming most generators are similar, do you run it for short periods of time, and if so, have you had any problems with it?
Under these conditions is why Onan wants the regenerator started and ran with some load once a month per the time/load stated in the owners manual. On any engine I run just to exercise it I like to run until the exhaust becomes dry meaning the muffler should not be holding water. We run Sea Foam to prevent needing to run the generator when not in use.
Source of below info.Exercising Your Generator
It may seem surprising that “not” using a machine could cause performance
problems, but with RV generators that’s exactly the case. Regular “exercise” is
an important part of keeping your generator healthy. Lack of exercise can cause
moisture build-up and fuel system degradation that make it run poorly. In fact, in
as little as 30 days, the fuel in gasoline-powered generators can begin to gum
and varnish the fuel system. Fuel varnishing results in hard starting and surging. (A
surging generator never settles at a stable operating speed.)
To prevent such problems, it is recommended to run gasoline generators at a
minimum of 50 percent capacity (2000-watts, or one air conditioner for a 4000-watt
set) for two hours once every four weeks. This is necessary to help keep moving
parts lubricated, expel moisture and control fuel varnishing in the carburetor. A long
two-hour exercise period is preferable to several short periods. While traveling, this
can be accomplished by running the air conditioning. If you own a diesel generator,
regular exercising can help reduce internal condensation and helps keep seals
lubricated.
