Lititz55ExplorerFeb 17, 2015Running hotIt run hot 210 to 240 I put a new thermostat in . Both the electric and the motor fan works. its a 1992 winnebago Brave 30ft with a 454. Thank Jim
Lititz55ExplorerFeb 17, 2015I put new radiator cap on it call for 15lbwater pump how do you know if one going bad i have no leaks.the gauge is good i took a infrared and it about the same.radiator is good only has 54000 miles Thank Jim
Related ContentWhy no hot water?Running Hot!Ford V10 Running hot8.1 Engine Running Hot454 Running Hot
