Make sure the engine base timing is set correctly and that the timing advance in the distributor is working correctly.
Since you have an infra red thermometer, you should be able to aim it at different parts to see what is hot. Make sure the radiator, air conditioning condenser, and oil cooler are all free of bugs and debris so that air will easily pass through.
When does it overheat? Highway driving? slow speed? pulling hills?
